Mikrotik CRS326-24G-2S+ Crashes Randomly
I have Mikrotik CRS326-24G-2S+ that crashes randomly. It used to do it at least once a day and now it is happening multiple times a day now. I am using it as Layer 3 switch which is using full RouterOS, instead of using SwOS.
The only thing I did on the switch is inter-VLAN routing and OSPF to edge router, and Hotspot gateway for wireless router.
I don’t see the CPU is being used over 50% so I don’t think the CPU is the issue here.
When it crashes, it will automatically reboot on its own, but it will make the network unusable when that happened.
I couldn’t find any log to find out what causing the switch to crash. I have researched it and someone mention about the power issue on CRS100 series. However, I am using the original power adapter that comes with it, which is 24V 1.2A
Can you please help me?
Thank you
