Hello, I would like to inform you that my Mikrotik CRS326-24G-2S+RM device is unable to exceed a connection speed of 920 Mbps. In an environment where even lower-quality devices can reach 940 Mbps, this falls short of my expectations. Additionally, I have observed that the CPU usage during speed tests rises to around 90%. My setup is based on an FTTH infrastructure. I kindly request your assistance with this matter.
/interface ethernet set [find default-name=ether1] name=WAN
/interface vlan add name=VLAN35 interface=WAN vlan-id=35
/interface ethernet switch set [find] l3-hw-offloading=yes
/interface ethernet switch set [find] qos-hw-offloading=yes
/interface bridge add name=LAN vlan-filtering=yes igmp-snooping=yes
/interface bridge port add bridge=LAN interface=ether2 hw=yes
/interface bridge port add bridge=LAN interface=ether3 hw=yes
/interface bridge port add bridge=LAN interface=ether4 hw=yes
/interface bridge port add bridge=LAN interface=ether5 hw=yes
/interface bridge port add bridge=LAN interface=ether6 hw=yes
/interface bridge port add bridge=LAN interface=ether7 hw=yes
/interface bridge port add bridge=LAN interface=ether8 hw=yes
/interface bridge port add bridge=LAN interface=ether9 hw=yes
/interface bridge port add bridge=LAN interface=ether10 hw=yes
/interface bridge port add bridge=LAN interface=ether11 hw=yes
/interface bridge port add bridge=LAN interface=ether12 hw=yes
/interface bridge port add bridge=LAN interface=ether13 hw=yes
/interface bridge port add bridge=LAN interface=ether14 hw=yes
/interface bridge port add bridge=LAN interface=ether15 hw=yes
/interface bridge port add bridge=LAN interface=ether16 hw=yes
/interface bridge port add bridge=LAN interface=ether17 hw=yes
/interface bridge port add bridge=LAN interface=ether18 hw=yes
/interface bridge port add bridge=LAN interface=ether19 hw=yes
/interface bridge port add bridge=LAN interface=ether20 hw=yes
/interface bridge port add bridge=LAN interface=ether21 hw=yes
/interface bridge port add bridge=LAN interface=ether22 hw=yes
/interface bridge port add bridge=LAN interface=ether23 hw=yes
/interface bridge port add bridge=LAN interface=ether24 hw=yes
/interface bridge port add bridge=LAN interface=sfp-sfpplus1 hw=yes
/interface bridge port add bridge=LAN interface=sfp-sfpplus2 hw=yes
/interface ethernet set [find] mtu=1500
/interface vlan set VLAN35 mtu=1500
/ip address add address=10.0.0.1/24 interface=LAN
/ip dns set servers=1.1.1.1,1.0.0.1 allow-remote-requests=no
/ppp secret add name="XXXXXXXXXX" password="XXXXXXXXXX" profile=default
/interface pppoe-client add name=TT-FTTH interface=VLAN35 user="XXXXXXXXXX" password="XXXXXXXXXX" service-name="" add-default-route=yes
/interface pppoe-client enable TT-FTTH
/ip pool add name=DHCPPool ranges=10.0.0.2-10.0.0.254
/ip dhcp-server network add address=10.0.0.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.0.1
/ip dhcp-server add name=DHCPServer interface=LAN address-pool=DHCPPool
/ip dhcp-server enable DHCPServer
/ip firewall nat add chain=srcnat src-address=10.0.0.0/24 action=masquerade
/ip firewall filter remove [find where chain=forward and action=accept]
/ip firewall filter add chain=forward action=fasttrack-connection connection-state=established,related,untracked hw-offload=yes
/ip firewall filter add chain=forward action=accept connection-state=established,related,untracked
/ip firewall raw remove [find where chain=prerouting and action=drop]
