No.
Customers may use every inner tag they like. We will sepperate them with the outer tag. (so if I am correct I need to create for every customer an bridge for the outer tag)
Is it correct that all examples are with innertag filtering?
We will use also normal vlans for our normal operation.
I assume we can mix that without undoing the outer tag sepperation.
If everything is wire speed and we can make qinq without any limitation for the customers, we have an winner!
