I recently bought a CRS326-24G-2s+ (Running 6.43.
and noticed a strange behavior on it.
Got 2PC, 1 Wired (PC1), 1 over Wifi (PC2) - (Through a Ubiquiti AP)
Both PC get an IP from Mirkotik over DHCP and can access internet through the default GW .254 (SP router)
However, neither of the PC can ping eachother.
Sniffer trace reveals that the PC are sending ARPs request properly, but they seemed to be dropped by the CRS, as the ARP request from PC1 to PC2 is not seen on the port of PC2 and vice versa.
(Devices are MAC and Linux based, and tried with several devices, the behaviour is the same).
Strangely enough, depending on what interface the PCs are plugged, it SOMETIMES works. (If I plug more devices, some devices have no problem accessing each other, some others can access some devices, but not all).
All ports are in the default bridge1 bridge and there is no special configuration on those ports.
I can ping all devices without issues from the router CLI directly and the ARP table on the CRS is correct too.
Topology:
…|CRS326..|
…|…|…173..±-----+
±-------+…|…±-----)))…(((—+PC2…|
|…|.254…|…|…|WiFi..|
|INTERNET±-------+…|…±-----+
…|…|…192.±-----+
…|…±-----------------+PC1…|
…|…|…|Wired.|
Config:
admin@MikroTik] > /export
add admin-mac=xxxx auto-mac=no comment=“created from master port” ether-type=0x88a8 name=bridge1 vlan-filtering=
yes
set [ find default-name=ether6 ] comment=PC1
set [ find default-name=ether23 ] comment=PC2
set [ find default-name=ether24 ] comment=Router
/interface vlan
add interface=bridge1 name=vlan17-mgmt vlan-id=17
set 0 limit-broadcasts=no
set 16 limit-broadcasts=no
/ip hotspot profile
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
/ip settings
set accept-redirects=yes
/interface bridge vlan
add bridge=bridge1 tagged=ether13,ether14,ether15,ether10 vlan-ids=17
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=192.168.88.0/24 dns-server=8.8.8.8 gateway=192.168.88.1 netmask=24
set servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=bridge1 src-address=192.168.88.2-192.168.88.253
add distance=1 gateway=192.168.88.254
/system logging
set 0 action=echo
set 1 action=echo
set 2 action=echo
/system routerboard settings
set boot-os=router-os
/tool sniffer
set memory-scroll=no
→ You’ll see some references to VLAN17, but it’s not in use right now, as I am still struggling to make things work in VLAN1.
Could you please give me a hand in understanding what I am missing here?
