jeevess
January 17, 2023, 11:51pm
1
I need to setup a point to point Internet link and apres lots of research I selected the MikroTik Cube 60 Pro ac device from the many different Mikrotik offerings.
So you can buy this in a predefined pair or as a single unit.
https://mikrotik.com/product/cube_60pro_ac
The dilemma is that I found a supplier of the single units at much less for a pair than the pre-configured.
Does anybody know how to configure the units manually?
Of course I went to the documentation and there is exactly ZERO information on the technical configuration.
https://help.mikrotik.com/docs/display/UM/Wireless+Wire+Cube+Pro%2C+Cube+60Pro+ac
I’m quite familiar with Router OS, and have at least 10 or so Mikrotik devices, but zero experience with the configuration of these
60 GHz units.
So please, does anybody have them and could perhaps do an export configuration and paste it here and explain the basics of howto?
Or a link to the same.
I feel like a CHICKEN not just ordering the units, but you might all recall your first time you went into router OS and thought !@£$%
thanks!
exports from some of the default configuration of the paired units, just read the read me then import and you should be laughing
CubeG-5ac60adpair-main.zip (2.49 KB)
jeevess
January 18, 2023, 11:06pm
3
What an awesome reply. I now have the confidence to go ahead with the order of 2 unpaired units.
I will post again with the hopefully good news.
thank you muchly.
Wireless Wire Cube Pro, Cube 60Pro ac - User manuals - MikroTik Documentation
I'm quite familiar with Router OS, and have at least 10 or so Mikrotik devices, but zero experience with the configuration of these
60 GHz units.
thanks!
there are only 2 model only Cube 60Pro AC and CubeSA (Sectoral Antenna) 60Pro AC.
You can configure it manually if you will get the stand alone which is the individual devices not the pre-configure devices.
I have 8 units of this Point to Point the far distance that I deploy is around 980m-1KM and I am surprise with the performance and bandwidth that I am getting of it.
jan/19/2023 09:14:16 by RouterOS 6.49.5
software id = 7UTW-XGVM
model = CubeG-5ac60ay
serial number = HCM0800WCM5
add name=BridgeAP
set [ find default-name=ether1 ] advertise="10M-half,10M-full,100M-half,100M-ful
l,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full"
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40mhz-eC
country="saudi arabia" disabled=no frequency=5825 installation=outdoor
mode=bridge name=wlan5ghz nv2-cell-radius=10 nv2-qos=frame-priority
nv2-security=enabled ssid=TW1APCPE tx-power-mode=all-rates-fixed
wireless-protocol=nv2 wps-mode=disabled
/interface w60g
set [ find ] disabled=no frequency=62640 isolate-stations=no mode=bridge name=
wlan60ghz put-stations-in-bridge=BridgeAP region=asia ssid=TW1APCPE
/interface w60g station
add mac-address=04:CE:14:FB:2C:06 name=wlan60-st parent=wlan60ghz
put-in-bridge=BridgeAP remote-address=04:CE:14:FB:2B:FD
/interface bonding
add mode=active-backup name=BondingAP primary=wlan60-st slaves=
wlan60-st,wlan5ghz
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=""
group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys
supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
