stuck at this point :
Are you, otherwise, able to access internet sites from router?
And another consideration: right now this forum feels sluggish to me (with 500 errors as well) which likely means that MT servers are under some kind of DDoS attack. And that likely includes DDNS servers as well.
obviously yes.
Well I had no issues starting up IP cloud on my hapax3 and then creating a BTH tunnel so the service seems to be working.
From Canada you probably connect to a different server
the arcane mystery revealed
