my MT soft is LQ3R-BR4T
Board Name is RB951Ui-2HnD
i am working with PPPOE Client
lan1 = wan
lan3 = lan
wlan = MT
hotspost + queue
this is my config
# software id = LQ3R-BR4T
set [ find default-name=ether3 ] l2mtu=1600 name=LAN
set [ find default-name=ether1 ] l2mtu=1600 name=WAN
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=2417 l2mtu=1600 mode=\
ap-bridge name=MT wireless-protocol=802.11
/interface wireless nstreme
set MT enable-nstreme=yes
/ip hotspot profile
add dns-name=www.msk.net hotspot-address=4.4.4.1 login-by=\
cookie,http-chap,http-pap name=hsprof1
add dns-name=www.roro.net hotspot-address=192.168.10.1 login-by=\
cookie,http-chap,http-pap name=hsprof2
/ip hotspot user profile
set [ find default=yes ] shared-users=4
add keepalive-timeout=20m name=FREE rate-limit=64K/64K shared-users=4
add keepalive-timeout=20m name=256 rate-limit=175k/175k
add keepalive-timeout=20m name=512 rate-limit=256k/256k
add keepalive-timeout=20m name=Bad rate-limit=333k/333k shared-users=10
add name=hs-pool-3 ranges=4.4.4.20-4.4.4.200
add name=hs-pool-8 ranges=192.168.10.2-192.168.10.254
add address-pool=hs-pool-3 disabled=no interface=LAN lease-time=1h name=dhcp1
add address-pool=hs-pool-8 disabled=no interface=MT lease-time=1h name=dhcp2
/ip hotspot
add address-pool=hs-pool-3 disabled=no interface=LAN name=hotspot1 profile=\
hsprof1
add address-pool=hs-pool-8 disabled=no interface=MT name=hotspot2 profile=\
hsprof2
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 \
default-route-distance=1 dial-on-demand=yes disabled=no interface=WAN \
keepalive-timeout=600 max-mru=1500 max-mtu=1500 mrru=1600 name=Te-Data \
password=xxxxxxx profile=default service-name="" use-peer-dns=yes user=\
xxxxx@xxxxxxx
/queue simple
add burst-limit=225k/225k burst-threshold=225k/225k burst-time=1m/1m max-limit=\
225k/225k name=30-EsLAM target=4.4.4.236/32
225k/225k name=30-Amr target=4.4.4.238/32
/system logging action
set 2 remember=yes
set 3 remote=0.0.0.0 src-address=0.0.0.0
add address=5.5.5.1/24 interface=wan network=5.5.5.0
add address=4.4.4.1/24 interface=LAN network=4.4.4.0
add address=192.168.10.0/24 dns-server=163.121.128.134,163.121.128.135 gateway=\
192.168.10.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.1 name=www.roro.net ttl=5m
add action=return chain=hs-unauth in-interface=LAN
add action=return chain=hs-unauth-to out-interface=LAN
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
to-addresses=0.0.0.0
/ip hotspot user
add comment="counters and limits for trial users" name=default-trial
add comment="counters and limits for trial users" disabled=yes name=\
default-trial
add name=rsrs password=7777
add name=rsrs1 password=7777
add name=rsrs2 password=7777
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept disabled=no server=hotspot2
/ip packing
add interface=LAN packing=compress-headers unpacking=compress-headers
add interface=WAN packing=compress-headers unpacking=compress-headers
/ip proxy
set cache-path=web-proxy1
/ip service
set telnet address=4.4.4.0/24 disabled=yes
set www disabled=yes
set ssh disabled=yes
set winbox port=66
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=no
/queue interface
set MT queue=only-hardware-queue
/snmp
set trap-community=public
/system clock
set time-zone-name=Africa/Cairo
/system identity
set name=EgyTik
/system logging
add topics=hotspot
/system ntp client
set enabled=yes primary-ntp=216.228.192.69
[UpDate@EgyTik] >
my problem is
dhcp server Leases not working with lan
but working with wlan
how to fix that
users on wlan get automatic ip
users on lan can’t get automatic ip
so they must use static ip manual in them pc and open mikrotik page manwaly by writting 4.4.4.1 in browswer
but in wlan hotspot page open automatically
and this image for dhcp server lease
ifast
June 21, 2017, 8:54pm
2
You have to configure 2 DHCP servers for both Lan and Wan Interfaces. You can also set wlan as parent interface in Lan and remove IPs from addresses from that interface. Now your LAN customers also get DHCP IP automatically.
Sent from my SM-N910T using Tapatalk
You have to configure 2 DHCP servers for both Lan and Wan Interfaces ؟
How can i do DHCP server for WAN?
i have 2 DHCP servers for LAN and WLAN
and where are this step?
((((You can also set wlan as parent interface in Lan and remove IPs from addresses from that interface))))
Please tell me the way!
Please Mikrotik administrator if her help me how to fix this problem !!!
any one can help me where is the error?
amt
June 23, 2017, 7:45am
7
why dont you delete all settings and create bridge add wlan and lan interface to bridge and assign ip to bridge. then create hotspot on bridge interface.
also in your settings;
if you are connecting your device to internet with pppoe_client why you assign ip to your wan interface ?
somtehing wrong in here ?
ifast
June 23, 2017, 6:05pm
8
khaloudy:
Sorry it was mistyped, I meant the same that you have to create 2 dhcp servers for Lan and Wlan interfaces.
amt:
this not for wan ip but static ip work for DVR
i did 2 bridges for lan and w lan and assign ip to bridges but the same problem
no automatic ip for clients
no lease for lan_bridge
amt
July 6, 2017, 8:31am
10
Please export your configuration please.
this is my config
export
[Up@Egy] > export
# jul/06/2017 13:59:44 by RouterOS 6.22
add name=BLAN
add name=BVLAN
add name=BWLAN
set [ find default-name=ether3 ] name=LAN
set [ find default-name=ether1 ] name=WAN
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2417 \
l2mtu=2290 mode=ap-bridge name=WLAN ssid=Egy \
/interface vlan
add interface=LAN l2mtu=1594 name=VLAN vlan-id=101
/ip hotspot profile
set [ find default=yes ] login-by=cookie,http-chap,http-pap
add dns-name=www.ask.net hotspot-address=4.4.4.1 name=hsprof1
add dns-name=www.ask.net hotspot-address=5.5.5.1 name=hsprof2
add dns-name=www.ask.net hotspot-address=6.6.6.1 name=hsprof3
add name=dhcp_pool1 ranges=6.6.6.2-6.6.6.254
add name=dhcp_pool2 ranges=4.4.4.2-4.4.4.254
add name=dhcp_pool3 ranges=5.5.5.2-5.5.5.254
add add-arp=yes address-pool=dhcp_pool1 always-broadcast=yes disabled=no \
interface=BWLAN lease-time=3d name=dhcp1
add add-arp=yes address-pool=dhcp_pool2 always-broadcast=yes disabled=no \
interface=BLAN lease-time=3d name=dhcp2
add add-arp=yes address-pool=dhcp_pool3 always-broadcast=yes disabled=no \
interface=BVLAN lease-time=3d name=dhcp3
/ip hotspot
add address-pool=dhcp_pool2 disabled=no interface=BLAN name=hotspot1 profile=\
hsprof1
add address-pool=dhcp_pool3 disabled=no interface=BVLAN name=hs-BVLAN profile=\
hsprof2
add address-pool=dhcp_pool1 disabled=no interface=BWLAN name=hs-BWLAN profile=\
hsprof3
keepalive-timeout=600 max-mru=1480 max-mtu=1480 mrru=1500 name=Te-Data \
password=9555494 profile=default service-name="" use-peer-dns=no user=\
2777776@tedata.net.eg
/queue simple
225k/225k name=30-Nasser target=4.4.4.130/32
225k/225k name=SSaid target=4.4.4.216/32
add burst-limit=333k/333k burst-threshold=333k/333k burst-time=1m/1m max-limit=\
333k/333k name=Said target=4.4.4.239/32
333k/333k name="Om Adham" target=4.4.4.237/32
add burst-limit=1k/1k burst-threshold=1k/1k burst-time=1m/1m max-limit=1k/1k \
name=Soad target=4.4.4.235/32
add burst-limit=512k/512k burst-threshold=512k/512k burst-time=1m/1m max-limit=\
512k/512k name=allinone target="4.4.4.70/32,4.4.4.71/32,4.4.4.72/32,4.4.4.73\
/32,4.4.4.74/32,4.4.4.75/32,4.4.4.76/32,4.4.4.77/32,4.4.4.78/32,4.4.4.79/32"
333k/333k name=blink target=4.4.4.226/32
333k/333k name=Essam.Net target=4.4.4.246/32
333k/333k name=GBS target=4.4.4.175/32
333k/333k name="Mahmoud CO" target=4.4.4.230/32
333k/333k name="Sh Adel" target=4.4.4.215/32
333k/333k name=AhmedAlex target=4.4.4.247/32
333k/333k name=Dr target=4.4.4.248/32
333k/333k name=Azza target=4.4.4.249/32
333k/333k name=TokTok target=4.4.4.242/32
333k/333k name="Moh SS" target=4.4.4.221/32
333k/333k name=DVR1 target=4.4.4.229/32
333k/333k name=DVR2 target=4.4.4.180/32
225k/225k name=30-Hamoty target=4.4.4.66/32
add burst-limit=400k/400k burst-threshold=400k/400k burst-time=1m/1m max-limit=\
400k/400k name=Maha queue=default/default target=4.4.4.220/32 total-queue=\
default
400k/400k name=Abou queue=default/default target=4.4.4.245/32 total-queue=\
default
add burst-limit=444k/444k burst-threshold=444k/444k burst-time=1m/1m max-limit=\
444k/444k name=Ganat queue=default/default target=4.4.4.184/32 total-queue=\
default
333k/333k name=Ayman queue=default/default target=4.4.4.225/32 total-queue=\
default
add bridge=BLAN interface=LAN
add bridge=BWLAN interface=WLAN
add bridge=BVLAN interface=VLAN
add address=41.32.207.111/30 interface=WAN network=41.32.207.180 >>static ip for dvr
add address=6.6.6.1/24 interface=WLAN network=6.6.6.0
add address=5.5.5.1/24 interface=VLAN network=5.5.5.0
add address=4.4.4.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=4.4.4.1 netmask=24
add address=5.5.5.0/24 gateway=5.5.5.1
add address=6.6.6.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=6.6.6.1 netmask=24
set allow-remote-requests=yes cache-size=4200KiB servers=8.8.8.8,8.8.4.4
disabled=yes
disabled=yes
add action=dst-nat chain=dstnat dst-address=41.32.207.111 dst-port=0-65535 \
protocol=tcp to-addresses=4.4.4.229 to-ports=0-65535
src-address=4.4.4.0/24
src-address=5.5.5.0/24
src-address=6.6.6.0/24
/ip hotspot ip-binding
add address=4.4.4.130 comment=Nasser mac-address= to-address=\
4.4.4.130 type=bypassed
add address=4.4.4.175 comment="Gar Basant" mac-address= \
to-address=4.4.4.175 type=bypassed
add address=4.4.4.237 comment="Om Adham" mac-address= \
to-address=4.4.4.237 type=bypassed
/ip hotspot user
add name=sock password=pa
add name=6 password=66 profile=Bad
add name=sm password=s111 profile=256
add name=st password=s1 profile=256
add name=sv password=s11 profile=256
/ip proxy
/ip service
set ftp disabled=yes
set winbox port=2016
/ip upnp
/snmp
/system clock
/system identity
set name=Egy
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set Te-Data disabled=yes display-time=5s
set BLAN disabled=yes display-time=5s
set BWLAN disabled=yes display-time=5s
set BVLAN disabled=yes display-time=5s
set WLAN disabled=yes display-time=5s
set WAN disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set LAN disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set VLAN disabled=yes display-time=5s
/system logging
add topics=hotspot
/system ntp client
/tool user-manager database
set db-path=user-manager
leases not working with LAN or LAN_BRIDGE
no automatic ip to any client mobile , pc or laptop too
lease working fine with wlan or wlan_bridge
auto ip working fin with wlan or wlan_bridge
w177f
July 6, 2017, 1:00pm
12
Your config appears fine.
What Rotuerboard are you using, and what device are you putting on Eth3 (LAN) to test?
w177f:
951Ui-2HnD
LAN3 To Access Point
Access point connected to PC with Cable
and wifi for Mobiles
i can connect only from mikrotik wifi and get auto ip easy
but from access or direct to pc or via switch no auto ip
w177f
July 6, 2017, 6:02pm
14
What happens if you connect your PC, and possibly another test device, directly to Eth 3?
trying long time to get ip and fail
if i enter manual ip its working
the same laptop longing automatically via mikrotik wlan
w177f
July 7, 2017, 10:13am
16
I would suggest trying a different device in addition to your laptop, and also updating your version of Router OS - 6.39.2 is the latest in current.
I have provisioned your config on a RB951Ui-2HnD I had spare.
I connected a RB2011 to Eth3, and the RB 2011 got an address straight away.
