Mikrotik DMVPN
Hi to all,
I have a compagny which want to move from cisco to mikrotik
But with their cisco infrastructure they have implemented DMVPN which permit to them to create dynamic tunell
How can I implement something similar on routerOS
Regars
MikroTik supports the basic components that make up a DMVPN network… Notably,
  • GRE tunnels (see the “/interface” menu)
  • IPsec (see the “/ip ipsec” menu)
  • OSPF, RIP and BGP are all supported (see the “/routing” menu and its submenus)
I don’t know about “NHRP”, unless that’s just “basic routing” we’re talking about, in which case, see “/ip route”.
The only “problem” for DMVPN in MikroTik is that, at least to my limited knowledge, there isn’t a trivially easy way to pull it all together, as supposedly Cisco can (I haven’t tried doing such a thing with them either, so I can’t say for sure…). You need to configure the individual components, for them to eventually achieve the same effect.
How can I do ? now
Please I need help
You can’t. The components are there, but not the management. And dmvpn is all about the management.
A wild (and un-educated) guess: could possibly Mesh be an option for you?
