I would like to request basic fixes in DNS cache support in Mikrotik. I have latest stable Mikrotik, which offers DNS over HTTPS. I don’t need that. I trust my ISP.
I would like, if my systems could rely on Mikrotik cache without features missing. Mikrotik DNS is not able to answer with EDNS https://tools.ietf.org/html/rfc2671. That extension is 20 years old. It enables bigger answer negotiation. You can check it by dig tool on Linux.
$ dig @192.168.88.1 | grep -A 2 OPT
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
Worse is, above is a requirement for Security Extensions of DNS https://tools.ietf.org/html/rfc4035. They are 15 years old. Mikrotik cannot do DNSSEC validation itself. That is unfortunate, but validation is not simple to do properly. Unfortunately Mikrotik also does BLOCK validation attempts to any systems using it as a cache. DNSSEC is ultimate protection against DNS poisoning. It ensures original data from authoritative server is unmodified anywhere in the chain of caching servers. It can then be used for verifying authenticity of signed domains. It can help in verifying SSHFP records are valid and not ask for guessing of fingerprint.
DNSSEC helps with protection against http://saddns.net, renewed attack to poison DNS caches. Compare two outputs of delv, which verifies domain integrity.
$ delv @192.168.88.1
;; validating ./NS: got insecure response; parent indicates it should be secure
;; insecurity proof failed resolving './NS/IN': 192.168.88.1#53
;; resolution failed: insecurity proof failed
$ delv @8.8.8.8
; fully validated
. 85631 IN NS i.root-servers.net.
. 85631 IN NS j.root-servers.net.
. 85631 IN NS e.root-servers.net.
. 85631 IN NS h.root-servers.net.
. 85631 IN NS m.root-servers.net.
. 85631 IN NS b.root-servers.net.
. 85631 IN NS d.root-servers.net.
. 85631 IN NS f.root-servers.net.
. 85631 IN NS c.root-servers.net.
. 85631 IN NS g.root-servers.net.
. 85631 IN NS a.root-servers.net.
. 85631 IN NS l.root-servers.net.
. 85631 IN NS k.root-servers.net.
. 85631 IN RRSIG NS 8 0 518400 20201129050000 20201116040000 26116 . B7WRRgtaFLLyv4lLSnjwaQ1D960t9wA94pRjld1guuA75veJ2Ocgw3/a e0sFAhNNm72IBfLNiVBL0fMKfijcuEPUxCRKqnMxBPlh+06BuHG667SJ j9Al+Egsjl51voI6tO9I9MureaHtkIHlw2t3kIzhiSZxJpDWLMV8bcIa DKpQyUpXVr+Fw4eyZp2JlijDLEPt+jwdDW2R7MY0OhRydcOQTq2gUtQH RtWv5P8VYAHLoVH0ZLNuLYNM+MYNvNScG1eDhKdH8jp/KcOUy0RP7ozo tjegv2KePcIgbxjoI38U0sFFsSUhA1ToY8usfl3ZBzZFBzXtdXbhqPLV NGSA1Q==
Until Mikrotik can do validation, please stop at least blocking of Security Extensions records. Not, following dig output is missing OPT PSEUDOSECTION and RRSIG records.
$ dig +dnssec @192.168.88.1
; <<>> DiG 9.16.8-RedHat-9.16.8-1.fc32 <<>> +dnssec @192.168.88.1
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 12344
;; flags: qr rd ra; QUERY: 1, ANSWER: 13, AUTHORITY: 13, ADDITIONAL: 26
;. IN NS
;; ANSWER SECTION:
. 422007 IN NS h.root-servers.net.
. 422007 IN NS e.root-servers.net.
. 422007 IN NS k.root-servers.net.
. 422007 IN NS i.root-servers.net.
. 422007 IN NS m.root-servers.net.
. 422007 IN NS g.root-servers.net.
. 422007 IN NS l.root-servers.net.
. 422007 IN NS c.root-servers.net.
. 422007 IN NS a.root-servers.net.
. 422007 IN NS b.root-servers.net.
. 422007 IN NS d.root-servers.net.
. 422007 IN NS f.root-servers.net.
. 422007 IN NS j.root-servers.net.
;; AUTHORITY SECTION:
;; ADDITIONAL SECTION:
h.root-servers.net. 76408 IN A 198.97.190.53
e.root-servers.net. 76408 IN A 192.203.230.10
k.root-servers.net. 76408 IN A 193.0.14.129
i.root-servers.net. 76408 IN A 192.36.148.17
m.root-servers.net. 511859 IN A 202.12.27.33
g.root-servers.net. 113513 IN A 192.112.36.4
l.root-servers.net. 76408 IN A 199.7.83.42
c.root-servers.net. 76408 IN A 192.33.4.12
a.root-servers.net. 508409 IN A 198.41.0.4
b.root-servers.net. 579151 IN A 199.9.14.201
d.root-servers.net. 461114 IN A 199.7.91.13
f.root-servers.net. 461114 IN A 192.5.5.241
j.root-servers.net. 76408 IN A 192.58.128.30
;; Query time: 3 msec
;; SERVER: 192.168.88.1#53(192.168.88.1)
;; WHEN: Po lis 16 19:25:42 CET 2020
;; MSG SIZE rcvd: 813
Note, DNS over HTTPS helps with protection against cache poisoning in one hop. But it does not provide any integrity protection against spoofing on remote endpoint. DNSSEC can to that with or without DNS over HTTPS. It is not replacement, but an addition to it.
Please, if you would like modern DNS cache like me, raise a ticket at support. Do not require users to skip using Mikrotik as their cache. Thanks!
