Dear team,
I’m facing a problem with mikrotik ROS long-term version, when i restart my CCR , it does not come online , untill i put power manually , what are the reasons may have for this problem?
Dear team is reading e-mails sent to support@mikrotik.com .
My suggestion, coming from ordinary user and fellow forum member, is to hook-up serial cable and observe output when you issue reboot command. When you get some concrete information about what’s happening with router during reboot contact dear team via e-mail.
Re Mikrotik on-line after restart
Does your Mikrotik never come back after a restart ? If so, try this … put it in a refrigerator for 10 minutes then take it out - power it up and restart it. If it now comes back after a restart when the Mikrotik is cold , then you hay have a thermal problem. If you detect that you have a thermal problem, one possible solution is set the CPU to operate at the next slower CPU clock speed and see if that works. ( slower CPU clock speeds normally result in a cooler CPU/motherboard ).
North Idaho Tom Jones
