Mikrotik does not compatible with some Intel board or what ?
My hardware detail are
Motherboard: Intel S3210 SHLC
Processor: Intel Xeon 3110
Ram: 2GB (EEC)
Case + PS: 350w
Hard Drive: 500 GB SATA NS (only for proxy cache)
ROS v3.15: installed in USB Flashdisk 1GB (Kingston)
My problems are:
  1. The clock was never synchronize with NTP Server. The “second” count each 3 seconds (so 1 minute is 20 seconds, weird !!!).
  2. Ping from winbox to any host always show in-accurate latency.
ping http://www.yahoo.com
209.131.36.158 64 byte ping: ttl=48 time=670 ms
209.131.36.158 64 byte ping: ttl=48 time=710 ms
209.131.36.158 64 byte ping: ttl=48 time=660 ms
209.131.36.158 64 byte ping: ttl=48 time=680 ms
But if I ping from the PC behind router, latency is normal
Pinging http://www.yahoo-ht3.akadns.net [209.131.36.158] with 32 bytes of data:
Reply from 209.131.36.158: bytes=32 time=225ms TTL=46
Reply from 209.131.36.158: bytes=32 time=252ms TTL=47
Reply from 209.131.36.158: bytes=32 time=321ms TTL=46
Reply from 209.131.36.158: bytes=32 time=226ms TTL=46
Reply from 209.131.36.158: bytes=32 time=248ms TTL=47
Reply from 209.131.36.158: bytes=32 time=255ms TTL=47
Reply from 209.131.36.158: bytes=32 time=228ms TTL=46
Reply from 209.131.36.158: bytes=32 time=247ms TTL=47
Reply from 209.131.36.158: bytes=32 time=246ms TTL=47
Reply from 209.131.36.158: bytes=32 time=246ms TTL=46
Each time after I reboot router, all back to normal. But…I must reboot everyday, because everyday those problems back. Sometime I reboot twice a day.
This router is brand new (I bought a week ago). Before, I use ASUS mother board + ROS installed in hard drive 80GB + Intel Pentium IV 3Ghz…and never had those problem.
Does mikrotik not compatible with my new hardware or any suggestion ?
Please help me to solve this problem.
FYI:
I backup my old router and restore data into my new router.
Old router was v3.10 and new router was start with v3.14 then now I already upgrade to v3.15
Is it the right way ?
Thanks.
/system hardware set multi-cpu=no ?
multi-cpu=yes
Should I make it NO ?
it should help
i tried multi-cpu=no but then the system does not work at all ! mikrotik has several problems with multi core cpus
I already made it NO. And now it work perfecto !!!
Thanks Chupaka. U save my life :wink:
Mikrotik team should have solution for multi core CPU. I hope nest version will be compatible for Multi Core CPU.
Thanks.
