mikrotik does not recieve incoming messages from radius
I have a freeradius server and my mikrotik device as a hotspot. authentication and accounting works fine, but when I want to use radclient, does not work.
how can i troubleshoot this? i tested a few other port numbers as well as 3779 but it did not work
# echo 'User-Name=test1' | radclient -x x.x.x.x:31340 status somesecret
Sending Status-Server of id 162 to x.x.x.x port 31340
        User-Name = "test1"
        User-Name = "test1"
        User-Name = "test1"
radclient: no response from server for ID 162 socket 3
[admin@HOTSPOT] > radius incoming print
  accept: yes
    port: 31340
I don’t use radclient, but I can maybe help you get started troubleshooting this. Have you enabled radius logging in the router? This enables logging.
/system logging
add topic=radius action=memory
Try radclient again and see what the log in the router says about it.
Nothing in the firewall filter rules that would block this, is there?
yes logging is enabled and the only logs i see is for accounting request and response
17:33:32 radius,debug,packet sending Accounting-Request with id 9 to x.x.x.x:1813
17:33:32 radius,debug,packet received Accounting-Response with id 9 from x.x.x.x:1813
17:33:32 radius,debug,packet     Signature = 0x154cff257cc9b8009cd6815ed7a56f04
17:33:32 radius,debug received reply for 3f:30
17:33:32 radius,debug request 3f:30 processed
I noticed in the radclient docs that it is a radius client program designed to communicate with a radius server. The router is a radius client. Could that be the problem?
http://wiki.freeradius.org/Radclient
I don’t think the Mikrotik RADIUS client supports status messages. It only implements Disconnect-Messages and CoA.
Last time I tried I couldn’t make CoA work with the FreeRADIUS radclient from the 2.x tree, only 1.x would work.
yes it seems you are right, i found this in another thread
only HotSpot supports Radius incomming (CoA and Disconnect requests) at the time. PPP does not.
http://forum.mikrotik.com/t/problem-with-disconnect-radius-user-from-radclient/29612/1
now I am trying to send a disconnect command to Mikrotik. this time mikrotik says:
 18:30:56 radius,debug received remote request 46 code=Disconnect-Request from y.y.y.y:54728
 18:30:56 radius,debug sending Disconnect-NAK to remote request 46
 18:30:56 radius,debug,packet sending Disconnect-NAK with id 218 to y.y.y.y:54728
 18:30:56 radius,debug,packet     Signature = 0xa11b6a474ad3ef7a26f6b79e6847a9a4
 18:30:56 radius,debug,packet     Error-Cause = 406
 18:30:56 radius,debug,packet     NAS-Identifier = "Port10"
 18:30:56 radius,debug,packet     NAS-IP-Address = x.x.x.x
and hotspot error info debug in MT says
radius disconnect with no ip provided
and radclient says
 echo 'User-Name=taghi' | radclient -x x.x.x.x:3799 disconnect secret
Sending Disconnect-Request of id 144 to x.x.x.x port 3799
        User-Name = "taghi"
rad_recv: Disconnect-NAK packet from host x.x.x.x port 3799, id=144, length=40
rad_verify: Received Disconnect-NAK packet from client x.x.x.x port 3799 with invalid signature (err=2)!  (Shared secret is incorrect.)
radclient: no response from server for ID 144 socket 3
It appears the shared secret is incorrect. At least radclient thinks so.
FWIW, I use it to disconnect stale sessions on a VPN when they try to reconnect. Works fine. In my case, because the radius server has multiple IPs, I had to add another radius server in the MT with nothing checked (no login, hotspot, anything) with the ip and secret that radclient is coming from.
