mikrotik failed to connect on 5700 authentication timeout :?
hi i have a problem with a connection. i have a AP and station on line of sight but the station is not responding, the signal of AP is -67 and it is good i have others like -76 this one is driving me crazy.:stuck_out_tongue::P:P any help please. i have 2 others and are Ok the board is rb133. PLEASE HELP :confused:
data on Station and AP
interfaec wlan1:
mode ap-bridge
band 5GHz
security profile siguria
frequency 5700
interface AP_230:
name AP_230
type VirtualAP
MTU 1500
mac adress xx:xx:xx:xx:xx:6E
arp enabled
wirelesss
master interface Wlan1
ssid AP_230
max station count 2007
propertary extensions: post-2.9.25
โ€œcheckedโ€ default authenticate
โ€œcheckedโ€ default forward
WDS
WDS mode disabled
WDS default bridge none
WDS Default cost 0
WDS cost range 0
station script
interface wireless security-profiles add name=siguria mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk unicast-ciphers=tkip group-ciphers=tkip wpa-pre-shared-key=hgj4kjrpo5a98sdmhgj4kjrpo5a98sdm wpa2-pre-shared-key=hgj4kjrpo5a98sdmhgj4kjrpo5a98sdm
interface enable wlan1
interface wireless set wlan1 radio-name=Ap_230 ssid=keminet_230 frequency=5700 mode=station security-profile=siguria country=italy wds-mode=disabled wds-default-bridge=none disabled=no
ip address add address=10.2.3.149/30 interface=wlan1
ip route add dst-address=0.0.0.0/0 gateway=10.2.3.150
ip route rule add src-address=10.8.0.0/18 dst-address=10.8.0.0/18 action=drop
ip route rule add src-address=10.8.0.0/18 dst-address=10.2.0.0/22 action=drop
ip route rule add src-address=10.8.0.0/18 dst-address=192.168.2.224/32 action=drop
ip pool add name=pool ranges=10.8.57.66-10.8.57.126
ppp profile add name=profili local-address=10.8.57.65 remote-address=pool dns-server=217.24.240.3,217.24.240.4 change-tcp-mss=yes
ppp aaa set use-radius=yes accounting=yes interim-update=01:00:00
interface pppoe-server server add service-name=keminet interface=ether1 max-mtu=1480 max-mru=1480 keepalive-timeout=10 default-profile=profili disabled=no
radius add service=ppp address=192.168.2.224 secret=sekreti authentication-port=1812 accounting-port=1813 timeout=300ms
user print
user set 0 name=orion password=1qazxsw2
I sat with same problem today. Used a NS5 and it connected, yet a Mikrotik would not connect. Then reset config on the board I was tryng to connect to, an VOILA, all worked. Although this solved the problem I still do not know the original cause.
@johnD
please am having that problem now and i would apperciate a more explicit discription of what you are talking about.its a 2.4ghz link and its giving me the authentication timeout error i have -71db link and it used to work before until i had a rain and the antenaa got wet. i then remover the 1 watt amp and replaced with a 600mw card after that i still get -71db as signal strength but the connection always fails with authetication timeout.
So when you say reset the other side i woudl like to know if its the AP on the other side of you or the client. I dont think i can reset my AP but am sure i can reset my client.
I would be glad if you can respond soon.(its just a 10km link but i dont have quiet enough clearance)
