Mikrotik FleetUpgrade
Introducing Mikrotik FleetUpgrade. A bulk script, which can upgrade thousands of Mikrotik boards from v6/v7 to any v7 version. This is desgined to operate on ISP type networks, with large scale Mikrotik deployments, where those devices does NOT neccessary have Internet Access.
Version to upgrade to, as well as the required package files can be on an internal web / ftp server, the script automatically will upgrade v6 -> latest stable v6 -> v7 of your choice -> firmware
Script executes once on every reboot, and polls the web server to check if it is at the correct version, automatically starts the upgrade process on reboot if it isn't at the desired version.
Should be completely fail safe - quite a bit of testing went into it, and will soon be used to upgrade ~15K devices.
