I’m looking for a way to persist a :global variable so it survives a reboot.
Any ideas?
–jeroen
Any ideas?
–jeroen
Try store them in “comment”
What entity types would best be suited for such a comment?
–jeroen
The “/system note” is a good place. It is displayed at the start of every terminal session, but beyond that, it doesn’t ever “do” anything. Alternatively, you could create a custom disabled item at any menu, and use it as a comment. By virtue of being disabled, it won’t do anything.
OR (my preferred approach), instead of doing that, you could write a startup script in “/system scheduler” that initializes the global variables to whatever values you need.
Thanks. Since it’s related to log buffers, I decided to put it in this entry (which I need to bail out on if it doesn’t exist anyway):
:put [/system logging action print as-value where name=failedauth ]
The not so cool (or - even though it’s a bug - maybe cool), is that WinBox does not allow setting this comment.
–jeroen
Woot! You can set and retrieve the comment. But WinBox won’t show it or allow you to change it.
Pixie dust!
/system logging action set failedauth comment=12
:put [/system logging action print as-value where name=failedauth]
–jeroen
