Looking to revamp a RV Park / Campground and their wifi. Reading nv2 has had much needed improvements since ROS release 6.42… Promising!
Debating either to utilize all MikroTik products in this build, or goto Ubiquiti… I’m leaning more towards MikroTik as I can do hotspot + the dude and also leverage the radio’s in conjunction:
This is only a theoretical design setup at moment.. Can anyone give me input?
Base Radio or RADIO’s (backbone - CPE) 5ghz network
-utilize OmniTik 5AC as primary radio (AP bridge) OR utilize two(2) mANTBox 15s (240 degree coverage is all needed for setup)
-Have MikroTik SXT5ac units throughout park pointed back to the main OmniTik in station-bridge mode..
-on same pole >> MikroTik GrooveA 52ac… with 2.4thz Omni setup (connected to radio above for power and network).
2.4Ghz MikroTik Groove’s setup in AP mode to provide client connectivity…
Or should 5Ghz be rolled out as Backhaul PTP links and also 5Ghz for AP client device connectivity?
Ubiquiti outdoor AP’s are limited in selection unless use their “legacy” devices and do powerbox + Antenna
