Hello ,
am using Mikrotik RB800 , I tested it two month ago with its built in mikrotik OS with no problem , after that I flashed DD-WRT on a compact flash installed on the Router-board and used it and it worked fine also.
Today I tried to reuse the built in OS so I had to change boot sequence from Compact Flash to NAND .
using Hyper Terminal , boot the routerboard
Press any key within 2 seconds to enter setup
What do you want to configure?
d - boot delay
k - boot key
s - serial console
o - boot device
f - cpu frequency
r - reset configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
t - do memory testing
x - exit setup
I pressed (o) to change the boot to NAND Only then by mistake I want to exit and boot again I pressed (e) as a start character to the word exit and e as described above is used to fomat nand , when it ask me to press yes to confirm , I unplugged the power cable and plug it back then it showed me that kernel is not found ? did I format Nand by mistake ? what is the solution ???
any help please ???
