Just to add to my confusion i have various specific ports that map to various Servers on the firewall side of things,
i have about 6 different servers port 13200, 13300, 13400, 13500 each point to a different server and configured in the firewall to point to a server with port 3389
on the mikrotik i have placed those specific servers with their ports , I am able to connect to them internally but i am unable to connect outside of the network.
but outside of the network if i PING my ddns address i get my public IP so why is it not working? im so unsure and lost at the same time
Well not sure what you are asking…
First ISP modem/router you need to port forward the incoming ports to the LANIP of the Second Router on the ISP modem/routers private subnet.
This LANIP is also the WANIP of the second router.
IF the second router is a MT device, then you need to
a. ensure there is a forward chain rule allowing port forwarding
b. a dst-nat rule that recognized the incoming port and sends it to the LANIP of the fortigate router on the MTs (second router) private subnet ( also the WANIP of the fortigate),
Note: that for the MT device the incoming dst-port can be translated to a different TO port before it hits the fortigate router.
This is a typical triple NAT scenario, where the ISP has its own private network, the MT has its own networks and then the fortigate which has its own network behind it.
