Hello.
I’ve run Mikrotik with freeradius + dhcp + simple queue.
So, here you have a schema:
client asks dhcpd server for lease
dhcp server ask radius, and then gives an ip address to the client
dhcp server also set up a simple queue for the clients ip
Everything work ok, but I have a problem with renewing the simple queue.
DHCP client renews the lease, dhcp gives the renewed lease - but dhcp server DO NOT check radius if the speed od simple queue has changed ;-(((.
So I’m changing simple queue from 10/10 to 20/20 mbit/s(on the radius level), the clients renews the lease, but still having simple queue with 10/10 ;-(
Only after ‘releasing ip’ on the mikrotik ip dhcp client, the client gets new simple queue ;-(.
Even restarting the mikrotik dhcp CPE equipment, the client still gets 10/10 ;-(
Any ideas?
Best regards.
P.S- it runs on the CCR-36, and mikrotik 6.4 release.
Are you returning a session-timeout? Or are you just using the 3 day timeout from your stock DCHP server config?
Session-Timeout := ${lease time}
I suspect MikroTik’s DHCP server only checks RADIUS again when the Session-Timeout has expired. It may assume an infinite Session-Timeout if it does not receive a Session-Timeout value from RADIUS.
