Mikrotik + Freeradius
Is this possible:
  1. I have today a working FreeRadius installation that works perfect for authenticating users.
  2. I want to setup/install/configure the Mikrotik to set up a “Hotspot”
  3. I have several VLAN´s from my access points and want to set up a Hotspot on one of the VLAN´s.
  • Can anyone help me install/configure this?
Best regards,
Johan
Greetings!
The docs are a good reference on this service. The hotspot has a setup function that I find works well.
/ip hotspot setup
It will prompt for the interface on which you want to put the hotspot. All else is pretty much default, except:
if you are running a NATed net, when prompted for “masquerade network?”, enter “no”.
if you do not want to use SSL on the login page, enter “none” at the security certificate prompt.
enter a username and password when prompted, and use it to test the hotspot setup.
Then go on to RADIUS.
/radius add service=hotspot address=xxx.xxx.xxx.xxx secret=radiussecret
Replace xxx.xxx.xxx.xxx with the radius server IP and radiussecret with your radius secret
If you selected the defaults in the hotspot setup, it normally uses a hotspot profile called hsprof1, but do a
/ip hotspot print
to check for certain. Then:
/ip hotspot profile set hsprof1 use-radius=yes
Several steps more must be taken for all to work correctly. DNS, NTP, etc…and set a client for this in the radius clients.conf file.
Hit the docs for info on them.
Whew! Essay questions… :wink:
Hello SurferTim!
Thanks for response! :smiley:
Can i get remote access help from anyone of the Mirkrotik team?
  • I need help setting up the DHCP on the mikroktik also, so each VLAN that i have gets an special IP range
  • And then setting up the hostpot on one of the VLAN´s
Best regards,
Johan
I cant seem to get DHCP to work for VLAN networks.
:frowning:
Well divisionmd you are asking for some kind of premium support, that is not free; you can try to contact a local Mikrotik reseller, which usually has competent people, they will be happy to help you.
