mikrotik groove A-52HPn reset
how to reset mikrotik groove A-52HPn coz when i try to access it using my winbox i cant find it…
Can you touch the groove?
So yes see the picture push a 20 seconds on this reset switch (red dot).
So now disable your firewall and try connect with mac-address
yes i did it already but when im trying to connect using winbox it doesn’t appear… :frowning:
Have you disable the firewall from your PC
I have the same situation. I cannot touch the groove and cannot access it via Winbox. Yes, I see it but it has IP 0.0.0.0. I have even tried using the MAC
