Mikrotik Groove RAM problem...
I have small problem with both grooves HW. (AP - ST) after 20days there is only 7MB RAM free… ROS 5.14. Any ideas? Thanks After reboot → 18,2Mb
Why do you bother about free RAM? Just let it do it’s job and don’t worry while it is working.
…lol.
because now is 7mb free…after next 10 days will be only 2mb ram free…then groove is not accesible :slight_smile: understand? :slight_smile:
No, we don’t. You should consider that you are the only one with that problem and if you want to get help maybe you should give more details. Ram just doesn’t consume.
RouterOS is Linux based, not Winblows based :laughing:
Hi
We had the same problem. Talked to mikrotik that recommended that we should do a fresh install via Netinstall. Now we have a Uptime for about 19 days.
make a supout.rif file and send to support, we might be able to determine if a program is eating more RAM than it should.
OK Normis, I will do it :wink:
