Mikrotik hack descovered ?
Is this true ???
https://arstechnica.com/information-technology/2018/03/potent-malware-that-hid-for-six-years-spread-through-routers/
Search the forum. You will find the answer.
BartoszP,
If you cannot provide a useful post then don’t post at all. This is a reasonable question.
Nikutdk, I as well searched the posts for slingshot and did not find anything either. I believe that Winbox was upgraded to prevent the vulnerability. If anyone could help this discussion by providing a link to the relevant Mikrotik forum discussion, we would both be appreciative, I am sure.
Good Luck!
mblfone
I could write: “If you cannot use forum then please do not use it.”
Simple search https://forum.mikrotik.com/search.php?keywords=slingshot gives “two meters long” list of answers on this problem where the fourth is official Normis statement on this particular problem.
If you use modern look then:
