Mikrotik Handshake timeout problem
Dear supporters,
Iam facing huge problem from 2 days , 2 months ago i came to see that all clients are dropping continously with the error 4 way hand shake timeout, i was noticed that there is the huge interference with channels , So i scanned and using 14th channel which none are using in our city and running successfully without problems from the past 2 to 3 months
But yesterday onwards iam facing the error 4-way handshake timeout (15) error I dont know why i had done site survey and i came to no that no interfierence with tht channel andBut still having the same issue
Iam using RB532 with 2.9.27 oS , please suggest me the correct solution, iam lossing my business, i appreciate ur sincere advice
Thanks,
Sathish
Somebody maybe attacking you.
Can you switch to another security system instead of WPA ?
Yes i can switch to another security , but iam using accesslist also are u sure its an attacking issue, i f es how are they attacking
Can u please explain
Thanks,
Sathish
