MikroTik HAp AC: making transparent bridge to router via SFP
Hi all
I’m afraid I’m another newbie who probably should know better—please be kind!
I have my ISP router installed in my house. I’ve connected the router to a media converter with Ethernet; the media converter connects via a fiber cable to the MikroTik’s SFP module.
I have access to the Internet via the MikroTik’s inbuilt WLAN connections. However, what I would like to do is:
  • Have the ISP router issue IP addresses
  • Use the MikroTik as a transparent bridge (I think), both by accessing the Eth ports and the WLAN
  • Use the ISP router’s SSID and passwords
I connected the MikroTik to my router via Ethernet in order to make any changes.I first tried using the Bridge on WebFig and I managed to get the bridge to work, initially, but the MikroTik was still issuing IP addresses. Then I reset and just switched off the DHCP server from the WISP AP QuickSet menu, and then I couldn’t access the MikroTik at all.
I feel like I’m nearly there—just need a little help.
Thanks in advance!
