Dear mikrotik community,
I have a Mikrotik hAP AC². This evening, I had an electric power cut at my home. After rebooting, I noticed the router was not having any led on, and I don’t remember if it ever had.
After cutting the house power a second time and turning it back on, the router doesn’t give any IP. I don´t know if it work or not, as I don´t have any LED indicator that tells me, but I assume that if it doesn´t give any IP will the modem behind it with the same cable does, then this router is dead.
May I ask, as I don´t have any clue:
- Should it show a led indicator when connected to LAN ?
- Should it show a led indicator when connected to power?
- If the cable connected to the router, can give an IP address to my laptop, but the router cannot give one when connected directly to my laptop, is the routeur dead?
Best regards, DK
