I’m having issues with Windows 10 laptops in my home network.
Thing is, that (randomly) I’m not able to connect these to the network (via wifi), no issues with Android devices though.
I’m getting this error message in Windows 10: “Can’t connect to this network”.
Only thing that helps is to connect to the Mikrotik router via Android app & reboot it.
Basically, I’m using hAP ac² as a main router and have connected 2 older TP-Links via ethernet with DHCP off, which are serving as an extenders.
Network setup is following:
Mikrotik hAP ac² → TP-Link SG105 Switch → TP-Link WR1043ND (Using as repeater, DHCP off)
WR1043ND Settings:
Mikrotik hAP ac² → TP-Link WR741ND v4 (Using as repeater, DHCP off)
WR741ND Settings:
Mikrotik IP Pool settings:
Could there be a problem in a way how are these TP-Links set?
Signal from WR1043ND and Mikrotik could overlap if it matters. Everything is connected via Ethernet cables.
Thanks in advance for your help!
