Mikrotik hAP ap2 can't find internet
Hi. My problem is that my Mikrotik hAP ap2 don’t see an internet when I plug it to provider’s cable. If I plug it in my old router it works fine.
My config is:
# oct/24/2020 12:32:12 by RouterOS 6.47.6
# software id = 9X4L-85U8
# model = RBD52G-5HacD2HnD
# serial number = D7160C005D0B
add admin-mac=48:8F:5A:C2:25:3A auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=wifi \
    supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge security-profile=wifi ssid=35-2 station-roaming=enabled \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge security-profile=wifi ssid=35-2-5 \
    station-roaming=enabled wireless-protocol=802.11
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
    192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system clock
set time-zone-name=Europe/Kiev
/tool mac-server
/tool mac-server mac-winbox
Please, help me to fix it.
You can connect to the router, so that’s good. I’m not a fan of anything after 6.45.8 - too many bugs reported - so I would downgrade and reset the default config. Your modem is set to bridge mode with NAT disabled if it has a built-in router, right ? Use Quick Set Home AP in Winbox.
With your WAN connected to ether1, do you see your WAN ip/Gateway in Quick Set or DHCP Client ? If not, try resetting your modem. Try adding a DNS server like 1.1.1.1 or 8.8.8.8 in /ip dns (you can add more than one). Make sure your clients are listed in DHCP leases. Can you ping 1.1.1.1 ?
I will try to look at your config more thoroughly today, but a default config should work for a simple client-WAN connection through the router.
