Right, i disabled WPA3 and used wpa2 psk with CCMP and hits 700Mbits, doable.
I have these speed issues too, i have 1Gbit internet and get 150Mbits on wifi 5GHz with my iphone 16 pro, so slow.
Is there a fix yet?
Please help me out...is it 700Mbps or 150Mbps?
At what rate is the iPhone connected?
What does your config look like?
/interface/wifi export
Remove serial.
It is the preconfigured settings and wifi1 2.4GHz disabled.
# 2026-02-04 09:30:57 by RouterOS 7.21.2 # software id = ES1A-G9IZ # # model = E62iUGS-2axD5axT # /interface wifi set [ find default-name=wifi1 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=Sweden .hide-ssid=yes .mode=ap .ssid=MikroTik-D10D5A security.authentication-types=wpa3-psk .ft=yes .ft-over-ds=yes set [ find default-name=wifi2 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80/160mhz configuration.country=Sweden .dtim-period=3 .hide-ssid=yes .installation=indoor .max-clients=3 .mode=ap .ssid=MikroTik-D10D5A disabled=no security.authentication-types=\ wpa2-psk .encryption=ccmp .ft=yes .ft-over-ds=yes
No default-config, same wifi settings as ramses, datapath to a bridge with eth connected to iperf3 pc
Hits 600mbps with "old" iPhone 14 pro max
iPhone is shown registered @1200Mbps Tx/Rx on wifi interface.
