Mikrotik Hap ax2 not working on 5Ghz
My new Mikrotik Hap ax2 router stopped working on the 5Ghz band after two weeks of continuous use.
I suspect interfereence from local radar or other 5ghz systems.
Using Winbox, I have been unable to change the frequency so as not to interfere with radar in the area.
I live in the USA and have set the router for “United States”.
Can someone please tell me how to fix this?
Sincerely,
dbjames
Could it be hardware failure? I know MT devices are known to be reliable, but since you say it worked for two weeks and then suddenly stopped, it sounds a bit suspicious. I suspect others on the forum would like to see your configuration to be able to properly help you.
Please share your config, so we can rule things out:
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by using the </> button.
</interface bridge
add comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ac .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.country="United States" .mode=\
    ap .ssid=MikroTik-5ghz disabled=no security.authentication-types=\
    wpa-psk,wpa2-psk .ft=yes .ft-over-ds=yes .group-encryption=tkip
set [ find default-name=wifi2 ] channel.band=2ghz-n .skip-dfs-channels=\
    10min-cac .width=20mhz configuration.country="United States" .mode=ap \
    .ssid=MikroTik-2ghz disabled=no security.authentication-types=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge interface=ether1
add address=192.168.1.2/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip dhcp-client
add comment=defconf interface=bridge
/ip dhcp-relay
add dhcp-server=192.168.1.1 disabled=no interface=bridge name=relay1
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan type=A
/ip ipsec profile
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main \
    suppress-hw-offload=no
/ip service
set ssh address=0.0.0.0/0
/system clock
set time-zone-name=America/New_York
/system identity
set name=glodenhouse
/system note
set show-at-login=no
/tool mac-server mac-winbox
set allowed-interface-list=LAN>
Leave channel.band unselected. It will figure it out on its own.
And manually specify the frequency to be used to avoid you get something subject to DFS.
FT settings are useless when you use different ssid.
AX devices support (and sometimes prefer) the U-NNI-4 frequencies … not every client supports those. If AP selects frequency not supported by client it’s ad good as not transmitting.
You can check which actual frequency uses AP by running
/interface/wifi/monitor wifi1
or in GUI by clicking wifi1 in list of interfaces and unfolding “Status”.
This works:
/interface/wifi
set [find default-name-wifi1 ] disable=yes
:delay 10000ms;
set [find default-name-wifi1 ] disable=no
It turns off the 5ghz, waits ten seconds and turns it on. Forces the dfs to search for a new frequency.
Regards,
dbjames
I thought it was working:
/interface/wifi
:delay 10000ms;
[code/]
The above solution worked for about a week and then quit working.
No 5ghz for about a month.
I live in a rural area in Texas.
What do I do now?
Try lower channel width if it’s actually caused by a radar
Like 20/40 mhz
