The most affordable Wi-Fi 7 router & access point for networks that need the flexibility and the power of RouterOS. USB-C powering, 2.5 Gigabit & Gigabit Ethernet, Wi-Fi 7 Multi-Link Operation, BE3600
Looking for Ethernet test results.
Apparently, there are several TP-Link devices that use the AN7563PT + MT7991 combination.
https://techinfodepot.shoutwiki.com/wiki/TP-LINK_TL-7_series
I am perplexed for two reasons:
- Power Is described as being USB-C, but It has to be seen if It Is the same mis-description that happens for the hAP Ax lite, which uses the USB-C connector but that Is NOT compatible with the USB-C power negotiation/check
- The device has max 12W, and the power supply Is 12W, the same as the hAP Ax lite, 5V 2.4A, but the Ax lite Is only 8W max power. So in this case It seems a bit "tight".
