Hi Guys,
I have recently purchased two Mikrotik hap lite (the stand one).
The first one is used as a router, dhcp server, caps man server and a wifi ap, the second one is set as a cap using caps man.
For this I did restarted the router while Holden’s reset 5 sec then another 5 sec to switch it to CAP mode.
It works like a charm, very nicely.
But then once the power is off, the device looses each of the setting and making a factory reset.
There is no ocean, the ap is inside a house, it’s a new one, bought it 2 days ago.
Should I send it back or there is something I miss?
Thank you in advance.
Best wishes,
Peter.
