Dear all,
I’ve bought a small MikroTik hAP lite TC with the idea of connecting it through wireless (as a client) to my existent home router, afterwards I could use its ethernet ports to connect some measuring equipment I have on the bench. Everything should be on the same network and if possible the home router should supply all IPs.
Using the quick config I’ve tried configuring the unit to CPE nonetheless it wasn’t working as I expected.
I’m overwhelmed by the amount of options, I wonder if someone could help me configure the unit for this purpose.
looking forward your reply,
Best regards, Mauro.
