I successfuly setup hEX as vpn server l2tp ipsec. I can connect from Windows client and access local lan on server side.
Now I wan to establish connection from hAP mini. From hAP I can ping router IP but no local server lan on server side..
hAP mini is behind NAT.
Config from office hEX:
# sep/16/2020 23:11:29 by RouterOS 6.47.3
# software id = 1KGD-95WT
# model = RB750Gr3
# serial number = CC210C571448
add admin-mac=48:8F:5A:58:C1:C3 arp=proxy-arp auto-mac=no comment=defconf \
name=bridge
set [ find default-name=ether4 ] arp=proxy-arp
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/ip ipsec profile
add enc-algorithm=aes-256,aes-128,3des name=profile_ipsec
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc
add name=dhcp ranges=192.168.40.100-192.168.40.200
add name=vpn_pool ranges=192.168.40.201-192.168.40.216
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add change-tcp-mss=yes local-address=192.168.40.1 name=profile_vpn1 \
remote-address=vpn_pool use-upnp=yes
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/interface l2tp-server server
set authentication=mschap2 default-profile=profile_vpn1 enabled=yes \
use-ipsec=yes
add address=192.168.40.1/24 comment=defconf interface=ether2 network=\
192.168.40.0
add address=WAN-IP-STATIC/27 interface=ether1 network=WAN-IP-STATIC-NETWORK
/ip dhcp-client
add address=192.168.40.0/24 comment=defconf gateway=192.168.40.1 netmask=24
set allow-remote-requests=yes servers=xxx.xxx.xxx.xxx
/ip dns static
add address=192.168.40.1 comment=defconf name=router.lan
add action=accept chain=input comment="Allow L2PT / IPSec VPN access" \
dst-port=500,1701,4500 in-interface-list=WAN protocol=udp
add action=accept chain=input dst-port=8291 protocol=tcp src-port=""
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-ah
add action=accept chain=forward ipsec-policy=in,ipsec
add action=accept chain=forward ipsec-policy=out,ipsec
established,related,untracked
in-interface-list=!LAN
invalid
connection-state=invalid
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=WAN-IP-GATEWAY
/ppp secret
add name=user1 profile=profile_vpn1
/system clock
set time-zone-name=
/system identity
set name=OFFICE_VPN
/tool mac-server
/tool mac-server mac-winbox
Config from hAP mini:
# sep/16/2020 23:33:29 by RouterOS 6.47.3
# software id = IKDN-RTL4
# model = RB931-2nD
# serial number = B7B10BAEBDC0
add name=bridge
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge ssid=MikroTik1 \
wireless-protocol=802.11
/interface l2tp-client
add connect-to=OFFICE-VPN-IP disabled=no name=l2tp-out1 use-ipsec=yes user=\
user1
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.90.100-192.168.100.150
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=wlan1
add interface=ether1 list=WAN
add interface=bridge list=LAN
add address=192.168.90.1/24 interface=ether2 network=192.168.90.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.90.0/24 gateway=192.168.90.1 netmask=24
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=l2tp_offfice \
passthrough=yes src-address=192.168.40.0-192.168.40.254
add action=masquerade chain=srcnat out-interface=l2tp-out1
add distance=1 gateway=l2tp-out1 routing-mark=l2tp_offfice
Can any one check this.
Regards,
