Hi
I’m having trouble finding a list of supported x86 hardware (the list on the wiki isn’t that complete), so I thought I would ask it here. I’m reasonably sure the Intel Pro/1000 adapters listed below are supported because they are in the supported list. I’m not sure the Z68 chipset is supported. Also I’m wondering if the two onboard NIC are supported (asus.com reports the mobo to have one Realtek® 8111E and one Intel® 82579, both of them are not on the list on the wiki)
I’m thinking of assembling this system to serve as a core router for our network
GPU ASUS EAH5450 SILENT/DI/1GD3(LP)
cpu Intel® Core™ i5-2300
psu be quiet! Pure Power CM L8 730W
mobo ASUS P8Z68 DELUXE
RAM Corsair 8 GB DDR3-1333 Kit
DVD Sony Optiarc DDU1681S-0B
casefan Aerocool Shark Fan 14cm Black Edition
NIC1 Intel® PRO/1000 MT Dual Port Server Adapter
NIC2 Intel® PRO/1000 MT Dual Port Server Adapter
CASE Chieftec UNC-310RL-B
HDD1 Corsair CSSD-F60GBGT-BK
HDD2 Western Digital WD2500AAKX
I am buy moterboard P8Z68-V LX.
Install mikrotik 5.14 on USB flash
system display on console Disabling IRQ #19 (where 19 - IRQ network card )
after display this messages reduced network performance. ping is 100 ms. before display messages “Disabling IRQ #19” ping is 2 ms
I am use two network card Intel Pro/1000 GT
CPU - Core i3
The same problem with D-Link DGE-528T in PCI slot’s. And this adapter don’t visible in System - Drivers.
In my configuration 3c905C-TX/TX-M works and Intel Gigabit CT Desktop [EXPI9301CT] PCI-E x1 works.
