mikrotik have a bandwith show tool like trafshow or pftop?
mikrotik have a bandwith show tool like trafshow or pftop? Please dont say me ; IP-Firewall-Connections . Because this section show only connections.It is dont show BYTES.
Yes, it have try tools->Torch…
I think you dont know trafshow or pftop.They are show online ip to ip connection bandwith.So I try Traffic Flow.Bu this is not usefull.Torch is show interface bandwith and this is so basic.thank you for your basic answer.
This is basic for you???:
Torch is powerful tool but it has limitations.
For an example, I want to see what connectios are used by one of my users to Internet. Torch cannot be limited to that request. It can show you all connections (my users can connect to each other and always have such connections), or connections targeted to some IP class. You cannot set Torch to show connections originating on one interface and going to another, limited by source IP, for instance.
What is actually missing in MT is some tool similar to torch but which can show connections which are processed by some firewall rule, queue/simple queue, or mangling rule or combination of them. That would be very helpful and allow us to investigate connections to the bottom.
You can use traffic-flow (it is the same as netflow) with a netflow server.
John
