Mikrotik hex as option 82 server
Does anyone know how to configure Mikrotik as option 82 DHCP server ?
Now I’m using Mikrotik hex fw 6.35 level 4
I’ve configured dhcp-server , and the switch on the other side accepts dhcp-address sucsessufully.
There is also option 82 configuration on the switch, & I can see Agent Circuit Id & Agent Remote Id that it sends on a Mikrotik
But there is no any configuration about options on Mikrotik that I’ve done.
I’ve try to add Option 82 in OPTION settings, but I dont see any changes in dhcp-debug
Is there any possability to activate Option 82 server ?
& also what is funcionary of “value” string ? what type of hex I can use for option 82 ?
Did you manage to figure anything out? I think it would be great if we could us Option 82 in the HEX Cpe in dhcp relay mode wth circuit id that we can set to the line-id and connect with dhcp/radius.
