MikroTik hEX PoE lite + USB wifi
Hi There,
i want to use the MikroTik hEX PoE lite to create a wireles clien bridge. (wireless CAT5 cable :slight_smile: is that possible?
is there a list of compatible USB wifi sticks, I put a belkin Wifi stick in the USB port and then…??
I need some guidense.
I’m probebly not the first one
Thanks in advange,
regards Victor
