Hi Guys
Quick question, would the MikroTik hEX PoE be able to power a UBNT AC PRO AP? According to my research, I would say yes with the correct PSU (48V), being the 48POW:
https://www.senetic.nl/product/48POW
Thank you!
Hi Guys
Thank you!
You wanna power it with hEX PoE or with 48POW???
Or you want power the AP with hEX PoE powered with 48POW It’s unclear…
Read everytime all the product specification first.
Ports 2-5 can power other PoE capable devices with the same voltage as applied to the unit
but:
PoE in input Voltage 8-30 V
DC jack input Voltage 8-30 V
You need this:
https://mikrotik.com/product/crs112_8p_4s_in
with
https://mikrotik.com/product/48POW
Hi
I want to power it with a hEX PoE which in its turn is powered by a 48POW. Where are you getting the info "8-30 V" from?
hEX POE can:
PoE in input Voltage 12-57 V
DC jack input Voltage 12-57 V
@ https://mikrotik.com/product/RB960PGS
Regards,
Hi Guys
Thank you!You wanna power it with hEX PoE or with 48POW???
Or you want power the AP with hEX PoE powered with 48POW It's unclear...Read everytime all the product specification first.
but:
DC jack input Voltage 8-30 VYou need this:
with
https://mikrotik.com/product/48POWHi
hEX POE can:
DC jack input Voltage 12-57 V@ https://mikrotik.com/product/RB960PGS
Regards,
I read here:
https://mikrotik.com/product/RB750UPr2
but is clear: i have digit wrong board model...:
sorry....
no problem, with 960PGS it working without problem …
Hi
Do you have the same combination running now (960PGS with 48POW + UBNT AC PRO)?
Regards
