Mikrotik hEX S RB760iGS and IPSec/L2TP VPN
Hi
I have problem with Mikrotik hEX S RB760iGS RouterOS 6.44.3. IPSec/L2TP VPN (Windows to Router) (Tested with two different devices).
All working I have access to internel network and over the IPSec/L2TP VPN tunnel internet,
but if I want access to router (with internal IP) itself using winbox or webpage that connection hang some 30 sec.
Over PPTP VPN that working.
I use that similar IPSec/L2TP VPN config to RB750G r3 and CRS125-24G and all working like works the way it should
Are there any ideas on how to get RB760iGS working properly?
