MIkrotik Hotspot and TendaW308R WirelessWan problem multiple client can login to a single shared hotspot user
I have a a tenda router w308R(192.168.0.1) and i connected this router via wireless wan to my mikrotik hotspot (192.168.1.1). My hotspot users only have 1 shared user , ` hotspot account one client. The problem is when the my client connects to my tenda router via wifi, instead of having 1 shared user, multiple phones and laptops connected to the tenda router can now login using only a single account.Multiple clients can now login with only one hotspot user. But if they login to my mikrotik wifi , it works fine. somebody help me. I think it can be a loophole to any mikrotik hotspot.
you have to bridge your tenda wireless so who ever tries to connect to your tenda wireless ssid the will be redirected to Mikrotik.
i believ you have already masquered the ip of your tenda address and that is why every client is able to connect to your tenda.
so :
1-make your tenda bridge to your mikrotik
2-run Dhcp on mikrotik bridge and run hotspot on that bridge and then try.
if it doesnt work please export your config here. so we may be able to help you properly
Sent from my SM-N910C using Tapatalk
Heres a scenario : I have a hospot user 3h657 and only has 1 shared user.
Now a client connects to my tenda ssid which is connected to mikrotk via wireless wan and tries to log in 3h657 and it says you are logged in.
Another client tries to login 3h657 still connected to tenda , and still says your are logged in instead “simutenous limit reached”. The mac add that is logged in the winbox is the mac of tha tenda router . the 2nd client that is logged with the same user wont appear in the winbx.
But works fine in my mikrotik ssid , the problem is th tenda.
I’ve tried wds bridging tenda to mikrotik and it works fine. Its jst this wireless wan mode of this tenda is a problem.
I ve tied ip binding the enda router mac add but still wont work ,
Do you have any suggestios
1-first of all disable DHCP in tenda.
2-let mikrotik provide ip
3- if mikrotik provide internet to the network so make it AP and connect Tenda station. otherwise make your Mikrotik station bridge.
however you must make your Mikrotik to give ip and Dns so try to bridge the tenda as well.
there are 4 essential requirement to run Hotspot on Mikrotik
1-Mikrotik must have Internet
2-DNS server
3-DHCP server on the specific interface
4-at least one user should be present.
so i hope you got the idea. if you need more help export you config and send it here
Thank you sir , I got it now , thank you very for the reply
glad to help. any time.
