I have setup a hotspot on an interface that has 2 IP ranges programmed.
- HotSpot range 192.168.16.0/24
- IP Camera range 172.19.0.128/27
I’m trying to exclude the second range from being caught by the Hotspot.
For this i have done an IP Binding with “bypassed” as the field. This is however not working. Bypass only seems to work on the 192.168.16.0/24 network
See below the firewall rules that get created by the hotspot
See below my IP binding with bypassed
Have you tried disabling the hotspot universal NAT?
/ip hotspot
set 0 address-pool=none
If 0 is not the line number of your hotspot, change that.
Hi Tim
thanks for your advise, i have changed the address pool to none but it is still blocking the IP Camera range
I’m guessing you are way past this, but did you add an IP address to that shared interface for the camera IP subnet to use as a gateway (e.g. 172.19.0.1), and do you have a route for same?
I have a similar setup with several hotspot access points on a subnet different from the range used by the hotspot. When those addresses are bypassed just as you did, I can ping a host on the Internet using a tool that is part of the access point. So it is possible.
Yes the cameras have a seperate gateway of 172.19.0.129 (172.19.0.128/27).
In the picture of the firewall rules it looks like you made modifications to accomodate the special 172.19.0.x subnet. In my case I did not make any changes to the default rules configured by the hotspot setup.
Also, my IP bindings are different. I list only Address, Server, and Type. I leave MAC address and To Address blank.
You will see the “D” tag on the left, this is a rule automatically created by the hotspot. IF i disabled the hotspot they dissapear.
Also, add the 172.19.0.128/27 network to the Walled Garden IP List of your Hotspot.
I realised why the rules 172.19.0.128/27 were automatically added by the hotspot. Its becuase i had already aadded them to the Walled Garden IP List.
Both SRC and DST of those Subnets.
Still blocks my connections
Have your tried to connect a computer to your camera network ?
If yes, does hotspot login page comes up? (it souldn’t), if not maybe something else blocking your connections…
The 172.19.0.129 gateway, how it’s connected to your mikrotik device?
Unfortunately i am remote from the site ±600km away.
Try in your IP binding to delete all data from “Mac Address” and “To Address”
