Mikrotik Hotspot Firewall
I configured a Mikrotik hot spot and added firewall rules to block p2p sites.
But realised when the firewall rules are enabled but dooesn’t get hits.
Any help on this please?.
Did you use this?
/ip firewall filter add p2p=all-p2p action=drop
If that is so, it does not work with p2p applications, you will have to drop ports to completely drop p2p traffic and this is sometimes difficult due to torrent applications on different ports.
Greetings to everyone I have 4 wan and 100 user hotspot and 1output dhcp wiht out lode blance how do it every 1wan 25 user clint hotspot from that change route batween 4 wan
I would mangle all the WAN connections together and then setup a PCQ queue to dynamically share all the bandwidth between all active users
in iraq lode blance Foreclosed due to corporate policy. iam do in caybrom server without lode blance from change gateway user hot spot to 1-4 Wan now do it in mikrotik without lode plance
i went hotspot without lode blance when i have 4 wan and 100 user div form change gateway only
