Mikrotik Hotspot for LAN and Wifi
I have configured my mikrotik router and set up hotspot successfully. In addition i connect the mikrotik router with a switch for LAN connections and then connected the swicth with a TPLINK wireless router for wifi connections. The login page appears on both LAN and wifi but the problem is if i login in with a single user everyone on the network will have automatic access without login using his own hotspot credentials.
Same problem here !!!
