Mikrotik hotspot function + usermanager + printer
Thans to many posts here and the replies on it i have now a full working hotspot and usermanager. When creating accounts i ve seen that there are companies that have a printer that work together with usermanager to generate a login and password on the fly. Maybe something that i can play around with :slight_smile:
Do you have such a printer and what is your experience? How do you create your vouchers with the login and passwords in usermanager? Do you print on a4 paper that you cut afterwards? Do you print on a ticketprinter? Do you have kind of businesscards with the login/password? Please share it!
Thank you!!!
Nobody?
Bump :mrgreen: :mrgreen:
You could make an application that uses the RouterOS API to generate/accept the credentials, and then both create the account in user-manager AND print them.
for home network environments it would be perhaps
running with this small program. readyVoucher
And for more business like networks or HotSpots you
could also try out this one here, it is a hotspot printer
that prints vouchers and also are creating in the MikroTik
usermanager directly. Handlink WG-500P M
