Mikrotik hotspot printers compatibility
Hi, I’m searching for a printer to generate temporary users (login and passwords) for an hotspot made with mikrotik.
Is there something not very expensive? they’re enough one or two buttons.
Thank you
perhaps it will be running with this equipment.
HotSpot Printer for RouterOS
Account generator
3 buttons
compatible with RouterOS
and the price must be found out by your self please
only cheap looking makes going you mostly twice buying a device :wink:
You can do this using my Account and Ticket Generator
I have made my software available in a website at the following location:
http://www.softreg.co.uk/HSGAccountTicketGenerator/
You can download it from there.
It will print tickets to just about any printer which is set up to print on a windows machine but is specifically designed to print to ‘strip’ tickets so will waste paper if you are printing to A4 or Letter (or similar).
I use a very simple POS58 thermal printer which I bought on eBay and it works fine.
The software must be licensed to get all of the functionality working (I may be persuaded to give a few licenses away for free to people who are prepared to help with testing it for me, not everyone though!).
It also uses an MS-SQLServer database for accounting which can be disabled. In theory, it should also work for other databases but I have not tried it and would be interested to hear from people who set it up to run against MySQL etc.
I will write up some documentation when I have chance as there are a lot of features which will need a little explanation.
Have a look, tell me what you think and we will see how well it works!
Dear,
How can this software be tested?
Kind regards?
PL
