Mikrotik Install
I want to know that does Mikrotik supports partition or not? I mean I have 4 partitions in my hard drive. When installing ROS it formats only drive C: or all partitions. And what about the drivers for LAN card, Graphics and others..
hai
when you install ROS it will format all partitions.it doesn’t need any drivers it will automaticaly detects all.
Installing RouterOS on a HDD will wipe and format the entire drive. The license will be tied to the physical drive as well, so it will take over. Any drivers are included in the OS, and you cannot add your own.
