Mikrotik Interface
Please under what circumstance can an interface on router got disabled automatically without manual disabling
Yes, using scripts and scheduler.
Regards.
Your question is a bit vague, are you asking to disable an interface other ways besides doing it manually or did you have an experience where the interface got disabled and all the technicians went “it wasn’t me”?
The latter can happen if loop protection has been configured whicc will physically disable the port of loop detected
