mikrotik inverter
hello everybody…i need big help…i have to many clients and i dont wanna dissapoint them again…i have the worst inverter of the world chineese…i need your suggestion to buy a new one…tripp lite 750 watt 12 volt ? i need also a power regulator …please suggest with pictures your best please
Finally im using tripp lite 12 v , 750 w !!! Mikrotik works fine with this inverter !
Is all of your equipment DC or combination of DC + AC ?, can you specify what voltage (s) are required.
Well, it depends first of all where are you located, on what you can put your hands on.
A tripplite 12V and 750W sounds to big for me, for just a router (max power 16W).
