Mikrotik ip models
Hello
Can sameone to explain me how you can find the users of the mikrotik model ?
How many ip it can have at the same time ?
What i can see in the models to understand the users the Level or you can se the hot spot user or with the ram and cpu ?
The number of users is not very relevant, what matters is the number of bytes per second, and somewhat the number
of connections. That is why you find no data on the number of users. It depends too much on the activity of
your users. “normal mobile user activity” like checking mail, facebook, twitter etc will be very different from “downloaders”
getting or viewing movies on their TV or getting the latest software packages (of several GB in size).
And how you decide what router and power equipment you will use ?
You need knowledge, and above all: experience.
You will not be able to run a thousand client ISP on a RB750. That should be clear.
On a CCR1036, that would not be a problem.
You will have to make estimates about the usage by each customer, the expected performance, etc.
There are almost no hard limits in the routers, but when you saturate the CPU of course the performance will suffer.
For each model, performance figures are shown on the datasheet.
you have one hotel that estimate to have about 1500 client per day to use viber, FB,Mail and other social media
you can put mikrotik CCR1036
If you have a cafe with 100 client per 2hour you can put an RB750
If you have a hotel with 400 client per day you can put RB2011
all the client you want the same Viber,FB,mal and other social
i am ok with this
